跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
260 个问题 查看全部
MacBook Pro won’t turn on after battery replacement
I just replaced the battery in my MacBook Pro 15” 2016 (using the iFixit replacement battery, tools, and guide) but now it won’t turn on at all. After the replacement, I plugged it in to charge as is instructed. A battery icon popped up on the screen, indicating that it was 76% charged. I then pressed the power button, the screen turned on for a split second and then shut off. Now zero signs of life no matter what I do.
I’ve tried all the recommended fixes that I can find (SMC reset, disconnecting and reconnecting the battery, etc.), and there are no visible signs of damage anywhere. At this point I’m worried that the logic board may have somehow been short circuited, but I’m not sure how that would’ve happened since I was extremely careful with my tools and there no signs of a short while I was working. Unless I scraped the logic board with the bottom case as I was putting it back on?
So I guess my questions are:
Does anyone have any idea what my be causing the computer to be dead?
Is it possible that the logic board was short circuited? What could’ve caused that?
Could this have to do with a faulty battery?
Any ideas for how to get it booted up again?
Thanks in advance for any input!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Have you tried running the machine without the battery connected? That way you can rule out the new battery as a potential cause.
Otherwise it's difficult to know. With battery installation, I would retrace your steps. Make sure all your cables are seated soundly. See if you get power if you disconnect other components (trackpad, touchbar, etc....)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Miranda Mertes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 82
