跳转到主内容
Seventh generation of iPad, released September 25, 2019, available in 32 or 128 GB models. Model Number A2197.
20 个问题 查看全部
How to Fix Loose Charging Port
After only a year of owing a brand new iPad 7th generation, the charging port became loose enough that charging it became a problem. For a while we were able to jiggle the charging cord around to get the pins to make contact inside the port and charge the iPad. But now it won’t charge at all and Apple wants more than half the original cost of the device to replace the charging port. Can I purchase a new charging port and easily replace it myself?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The charging port repair on I pads is a difficult job that without proper repair knowledge and skill can be difficult and risky. You may want to take it to a repair shop other than Apple or try to clean the charging port with IPA or BW 100 and clean out any possible dirt and/or debris with tweezers, nylon tipped preferably.
Good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nikki 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 20
总计 925
