跳转到主内容
加入维修社区 - 创建账户
The HP Compaq 8200 Elite is a small form-factor workstation-class desktop PC aimed at higher-end office and design work. It has a fairly repairable design with emphasis on allowing technicians to quickly swap out drives and cards.
问题已关闭
My PC tun on then immediately turn off
My PC is just boot looping, like it starts automatically when I give power then it just stars for 1 second (like fan and all run) and then every thing stops then again stars for 1 sec and every thing stops. But when it like actually run fully it stay on and no problem but right now it's just not starting, help me ma guyss much needed all my work is hanging.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Same problem
完成的
My HP Compaq 8200 elite ultra slim won't turn on at all
完成的
添加一条评论
4个答案
最有帮助的答案
My initial guess would be, there is something drawing too much current since the processor never seems to get to even try to boot the system.
Start by unplugging and/or disconnecting anything you can, one at a time. Like hard drives, removing ram, etx.
If you find nothing, remove the processor to see if it stays on. If so, it could be the processor or it may still be a MB problem.
Now you need to decide what you want to try to replace first.
这个答案有帮助吗?
得分 3
1条评论:
I will try it
完成的
添加一条评论
In my experience, the most common cause of boot looping is faulty RAM. Remove the ram sticks one by one. Try with a single stick in the first slot and see if things improve.
这个答案有帮助吗?
得分 3
1条评论:
Did you manage to solve this problem? I have the same one after disassembling, cleaning and reassembling...?
完成的
添加一条评论
Yo tambien intente, El pc arranca y se apaga. lo quiete ram, lo limpie, tambien cambie ranura y todavia sigue y no solamnet uno tengo tres asi, antes funcionaba normal. cuando quito la ram el ventilador queda encedidido y no se apaga
这个答案有帮助吗?
得分 0
添加一条评论
Masalah itu pertama RAM, kedua PROSESOR, ketiga Ada salah satu device yang bermasalah
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 1,574
