跳转到主内容
How to change charger pin
How to change realme 8i charger pin full details
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 10
4条评论
Display change
完成的
If you are looking for a display change, @dadibrokeit already gave you a great website to fix your phone. Here is the link for the display change incase you are unable to find it: https://www.nadiemellamagallina.com/en/m...
完成的
it's very simple if you have the right tools
完成的
Charge nahe hota h
完成的
添加一条评论
2个答案
已选择的解决方案
This may just be an artifact of auto translation, but I'm going on the assumption that you are asking how to change the USB-C charging port on your phone.
Sorry to say that iFixit doesn't have a guide for replacing that on your phone, but there's a Spanish site called Nadie Me Llama Gallina, or Nobody Calls Me Chicken, that does have just what you need. If you view it with the Chrome browser and allow it to do the translation, the guide is very much usable.
You're fortunate in that your USB-C port is mounted on a small auxiliary board mounted near the bottom of the phone and can be replaced by itself fairly easily. Here's the guide you need.
Manuals / Realme Narzo 50 (Realme 8i) / Auxiliary plate
You shouldn't have too much trouble locating a replacement part; I usually check sites like AliExpress, Amazon and eBay among others. Here's one of the first ones I found on a cursory search.
For Realme 8i Original Charging Port Board – Alexnld.com
Good luck with your repair; let us know if you need any help and be sure to tell us how it turns out for you!
这个答案有帮助吗?
得分 3
5条评论:
How to change charging jack
完成的
Did you bother to read the previous responses where that question was already answered? Please go do so before contributing nothing to the discussion.
完成的
Jack change.realme 8i
完成的
Please RTFM.
完成的
If you have a similar phone that is no longer in use you can take it apart and use that particular part for the other phone .
完成的
添加一条评论
Change charging pin
这个答案有帮助吗?
得分 0
1条评论:
I'm sorry, is there a question in there somewhere? If you are asking how to change the charging port on a Realme 8i, the answer has already been given so I don't understand why you are asking again.
完成的
添加一条评论
添加你的答案
Samiullah Ansari 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 54
总计 3,372
