跳转到主内容
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
197 个问题 查看全部
won't power on, I just smack the machine and then it powersup
I have similar issues , it seems to be a cold/cracked solderjoin somewhere , I just pull plug , drain caps , replug , sit 20m so caps will charge then power-up , if no reaction i just smack the machine and then it powersup. (eventually). - Unable to determine location , may be in the PSU(the issue).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
There's a specific issue with the G5 tower having a tendency to fail due to solder problems on the lead-free machines; the ones with leaded solder never had an issue.
It's the chip with the massive heatsink that goes bad on these, but the best practice is to treat both as bad because one going out is not so great; the other one tends to go out next. However, this is a TEMPORARY SOLUTION and not permanent. For a longer-term solution, you will need to replace the motherboard and ASD; you can look online for it, but I'm not providing a link (COUGH Macintosh Repository COUGH) once you calibrate the processors AND replace the motherboard that fixes the problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ediflorianUS 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 18
