跳转到主内容
Repair and disassembly information for the Nokia G22 Android smartphone, first released in March 2023, built by HMD Global. Identified by model numbers TA-1516 or TA-1528.
No Wi-Fi networks showing after about a day of use
So,
after about a day of normal use, Wi-Fi networks stop showing. I can't find any. I try and enable Airplane mode, disable and enable Wi-Fi, but no success. I have to restart for networks to show up again.
Had the phone for about a month, and I think the problem came after updating to latest system version ... Android 12, Security update on 5th June 2023.
Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Yes, you need to factory reset your phone, just add any important pics or contacts ect. To your email account to be saved first.. somewhere in update or possibly on accident the wifi Manger software has gotten deleted.
这个答案有帮助吗?
得分 0
1条评论:
Hello Chris,
thank you for your answer. Since I'm not super proficient in Android and I was wondering if there is a way to confirm that missing Wi-Fi manager software is at the root of this cause?
I can manually add and remove Wi-Fi networks, QR code scan and add also works. Hotspot also works as it should when I turn it on. Only the issue is the randomness of when the Wi-Fi goes dark.
I'm asking this, because it's quite a hassle to do a factory reset, and not being really sure, that this will eventually solve the issue.
Regards,
Darjan
完成的
添加一条评论
添加你的答案
Darjan Zlobec 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 491
