跳转到主内容
Repair guides and support information for Lenovo's Z series of laptops.
11 个问题 查看全部
What steps must I take to install a ssd on my lenovo z 50-70?
I tried replacing my HDD with a SSD but it shows the lenovo logo and nothing happens. I waited for 10 minute and tried presing f2, f8 and f12, but had no efect. Should I change something în my BIOS setting? I run the latest BIOS version for this model
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
I found this video online: https://youtu.be/kFbJoa9y52s
这个答案有帮助吗?
得分 0
1条评论:
I know how to replace my HDD, but I wanted to know if there are some necesary BIOS setting
完成的
添加一条评论
Hi @iulianmaties,
Did you "clone" the new SSD from the old HDD before replacing the HDD i.e. exact replica of the HDD.
Most SSD come with cloning software to make it a seamless uppgrade i.e. clone SSD using software, remove HDD and replace with SSD and turn on the laptop.
It will be like before except faster as you now have an SSD
Is there an OS installed on the SSD?
If there's no Operating System on the SSD the laptop won't boot.
You shouldn't have to change any settings in the BIOS for it to boot if you cloned it.
If you didn't clone it then if you're doing a fresh install you need to boot from an install USB disc and follow the setup procedure.
You need a bootable setup USB disk to do this.
这个答案有帮助吗?
得分 0
1条评论:
I will try to find a software ti clone my HDD. I only need the C drive, so it just be a bit more complicated, since I am going to use my HDD externa srorage via usb. So thank, I will just try this
完成的
添加一条评论
添加你的答案
Iulian Maties 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 10
总计 69
