跳转到主内容
The Toshiba Satellite L300 was a notebook designed and sold by Toshiba that came with a version of Windows Vista. They were sold around May-June 2009 and while ineligible for the free 7 upgrade, time past and upgrades are unclaimable now, run 7 home premium well without upgrades mainly because of Vista's resource hog quality. Also known as Toshiba Satellite L300-04P (PSLB8C-04P01X).
30 个问题 查看全部
My laptop is not working after long time (6 years) of not using?
I'm not using my laptop for around 6 years (was working before) now when trying to start up not working but charging light is working as before?
What I have to check and what problem could be?
I have to laptop satellite L300 & A300.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Haitham,
I'd say the first thing you need to do is get a new battery. Lithium Ion batteries don't have a six year shelf life, so if it's been sitting that long I doubt very much the battery is usable in any sense. It sounds like the charger is probably still working, but the battery isn't taking the charge, which is not surprising after all that time.
You could try removing the battery and plugging it into the AC adapter. It may or may not work; it's not necessarily a bad sign if it doesn't, but if it does that would indicate the laptop is functional and a new battery is probably all it needs. Of course, try leaving the charger on overnight; it may be so depleted that it will take a very long time to even start charging if it does at all.
But if you don't see any sign of life after leaving it to charge overnight, then I'd say the next step is a new battery.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Haitham Amer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 48
