I forget my password
I forget my mobile password so I rest my mobile how can you help me
A factory reset should clear all data and restore to factory defaults.
Of course, this is a problem if your data isn't backed up as you will lose it all.
这个答案有帮助吗?
Hi @ruggb,
A factory reset will reset the phone but it doesn't clear the password entirely.
If the phone has a Google account tied to it you still need to know the account ID and password to access the phone after a factory reset or know how to bypass the FRP lock (factory reset protection) that has been enabled in the phone by the reset to enable you to setup the phone again after the reset has been done. You only get so far into the setup procedure and no further as it asks for this information
FRP lock is a security feature in Android OS 5.1 and higher versions in case a phone was lost or stolen so that it couldn't be used again or onsold by simply resetting the phone back to its factory default condition as could be done with earlier versions of the OS
这个答案有帮助吗?
If you don't want lose your data you can use any tools for flashing or unlcock by any tool software. There are many tools you can use.
这个答案有帮助吗?
Yes if I long press on the buttons of power and volume it can be flashed now how to unlock it
这个答案有帮助吗?
过去 24 小时: 5
过去 7 天: 18
过去 30 天: 113
总计 1,115
5条评论
I don't know because I'm noob
由 Muhammad Fahim 完成的
I forget my phone password
由 Rama Mane 完成的
My phone was hanging,strucking,heating,full of storage
由 Mirza Mustafa Baig 完成的
hard reset my phone total reset forgo passwod unlck
由 manju manju 完成的
how to remove mobile paswarod
=== Update (01/07/24) ===
how to remove mobile passwrod
由 oppoA57 完成的
