跳转到主内容
加入维修社区 - 创建账户
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
What to do next?
I Order a cheap kit to replace LCD screen on XS Max and it didn't come with instructions or the right tools and stripped the bottom screws. I was stuck trying and trying then decide to open the phone in half and even replace the screen open but it just doesn't look the same as the phones in the videos and the replacement screen doesn't mount to my phone because of the metals around it so I ended up cuting and grinding them off....plz help!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Could you share some pictures to see what we're working with?
完成的
添加一条评论
2个答案
最有帮助的答案
It sounds to me like you purchased the wrong replacement screen. Can you send us the link to where you bought it? Also, what kind of screwdriver did you use to try to open the phone? Also, did you grind metal off of the phone chassis???
这个答案有帮助吗?
得分 1
添加一条评论
Hi Erika,
Okay, we've seen this sort of thing several times before. What you're seeing is the screen's frame that's supposed to come off when you remove the screen. However, what happens is, if you don't remove the Pentalobe screws, the frame remains very securely fastened to the chassis and you end up just removing the screen without the frame, leaving the frame on the chassis.
So the frame is still there, secured by the stripped Pentalobe screws. You're going to have to find a way to remove those screws, whether that's done by using a screw extractor, a Dremel on the frame, or drilling out the screws, they have to come out so you can get the old frame off the chassis. Once the screws are out, you can go through the screen removal process again, this time working on the frame all around the edges of the phone until the frame comes free.
After that you'll be able to put the replacement screen in. Here's another answer that demonstrates the issue.
Replacing my iPhone X screen but it's different than videos show - iPhone X - iFixit
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Erika Lopez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 34
总计 190
