Tecno Camon 11 not turning on after locking bootloader
I'm using tecno camon 11 after locking bootloader using miracle box, and the phone just shut down and I cant turn it back on of even use the recovery menu. Even the power button isn't working.
If your Tecno Camon 11 is not turning on and the power button is unresponsive, there are a few troubleshooting steps you can try:
Charge the phone: Connect your phone to a charger and let it charge for at least 30 minutes. Sometimes, a drained battery can prevent the phone from powering on.
Force restart: If the phone is not responding to the power button, you can try a force restart. This is usually done by holding down the power button and volume down button simultaneously for about 10-15 seconds. This action may vary depending on the specific device model, so you might want to consult the user manual or search online for the correct key combination.
Remove the battery (if possible): If your Tecno Camon 11 has a removable battery, try removing it and reinserting it after a few seconds. This can help reset the device and resolve any temporary issues.
Seek professional assistance: If none of the above steps work, it's recommended to visit an authorized service center or contact Tecno customer support for further assistance. They have the expertise to diagnose and repair hardware-related issues with your device.
It's worth noting that locking the bootloader and performing advanced modifications on your phone can have unintended consequences, including software or hardware malfunctions. It's important to exercise caution when making such changes to your device, as they can void warranties and potentially cause irreversible damage.
这个答案有帮助吗?
If you locked your bootloader after making modifications to the OS your device will refuse to boot as a security measure. Normally though, it will tell you that that is the case and not just stop working.
这个答案有帮助吗?
过去 24 小时: 5
过去 7 天: 24
过去 30 天: 94
总计 519
