跳转到主内容
The Kenwood Chef A701A is a stand food mixer released by Kenwood.
47 个问题 查看全部
Balloon whisk hub assembly service
The balloon whisk in my a701a KENWOOD seemed to be misaligned.
I noticed a small flathead screw in the middle of the hub assembly naturally I figured I’d undo this and see what was inside. Turns out it’s quite hard to realign the wires and reinstall the hub. anyone have any tips? Should I be regressing the hub? Is there an order to the wires?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi @sarahillarietti
Here are some images of the whisk that may help.
It shows what arrangement is used for the wires.
(click on image)
这个答案有帮助吗?
得分 2
1条评论:
Thank you, this will be helpful when I manage to reassemble :)
完成的
添加一条评论
Can you take a picture and show us here? Use this guide.
这个答案有帮助吗?
得分 1
1条评论:
I’ve updated the post with some pictures, I’m not sure if they are all supposed to be the same shape but one seems to have a point, although this may have been misshapen when it was poorly aligned. There was grease inside the hub, should I be cleaning this and replacing?
The issue I’m having is getting all the wires in, avoiding them springing out whilst also aligning the grooves in the hub top then being able to tighten the flat head in the middle without undoing all the prior.
完成的
添加一条评论
添加你的答案
Sarah Illarietti 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 66
