跳转到主内容
加入维修社区 - 创建账户
Repair guides and troubleshooting for the HP Compaq DC7500, a business class desktop computer introduced in 2007.
cpu fan is spinning very fast and no signal from computer no display
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
3条评论
Feni is on automatic soon is off.
完成的
Kendisi açılıyor kapanıyor
完成的
kendisi kapanıyor açılıyor
完成的
添加一条评论
3个答案
已选择的解决方案
Hi @geofreynazarius
Try a full power refresh, in case it is a corrupted BIOS that is the cause of the problem.
Turn off the PC if it is on - long press of the power button and then disconnect the power cord from the PC.
Open the PC and locate the coin cell RTC (Real Time Clock -aka cmos) battery on the motherboard and remove it from the motherboard. Whilst the RTC battery is out measure its voltage. If it is <2.5V DC replace it. It is a CR2032 Lithium non rechargeable coin cell battery that lasts about 4-6 years. It is commonly available e.g. supermarkets.
Here's an image of the motherboard for your PC showing the battery location
(click on image)
Press and hold the PC power button for a full 30 seconds and then release it.
Reinsert the RTC coin cell battery into the battery holder on the motherboard - +ve side up as marked on the battery.
Reassemble the PC and connect the power cord to the PC and try turning it on and check.
If it starts OK there may be a message regarding the Date and Time being incorrect. This is normal as the BIOS has been reset. Once the D&T have been corrected, the message won't appear the next time the PC is started.
Also if you have changed any user definable settings in BIOS to suit whatever specific operating requirements, these will have to be changed back again to what you had.
这个答案有帮助吗?
得分 1
添加一条评论
Updated the bios on five INTEL DH61AG's one of them bricked. Same symptoms as you describe. So I bought a ch34a chip burner version 1.7 with the selectable voltage switch. Pulling the bios off of one of the good boards updated the bricked MOB and was able to get it backup and running.
这个答案有帮助吗?
得分 0
添加一条评论
check Power Supply Green & groung wire blsck mix karo twezer say dekhu chal rahi ha agar ok ha tu cemos cell nikal kay dekhu
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
GEOFREY NAZARIUS 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 82
总计 7,128
