跳转到主内容
第五代 iPad Air 于 2022 年 3 月 8 日发布。它配备了 M1 芯片和 5G 网络连接。
18 个问题 查看全部
Do the iPad Air 4 screen adhesive strips work?
I want to know before purchasing if the adhesive strips for the iPad Air 4 are the same as the iPad Air 5, I see it recommends it with the guide to replace the 5th gen screen, but it doesn’t show it supports it in the item details. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The answer is YES!
The iPad Air 4 and 5 actually use the exact same screen, you can take the screen off of a 4 and put it on a 5 and it will fit perfectly and it will work.
So with that in mind, the adhesive strips are only cut to fit the shape and size of the screen, Since the screens are exactly the same shape and size, the adhesive strips will work interchangeably.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Max SinisterFX 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 52
