跳转到主内容
加入维修社区 - 创建账户
Repair Guide for the 2004-2008 Mazda RX-8. A Japanese sports car built from 2003 until 2008.
My battery light came on in the dash and would blink on and off I have
My 2004 RX8 standard shift rotary engine the battery light came on on the dashboard and I don't know why
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @wendyanne27695
The battery light is indicating that the alternator is not supplying the correct amount of voltage for the vehicle's electrics e.g. keep the battery charged and supply power to the rest of the vehicle's electrics (as required) when the engine is running.
Check for the following possible causes with the vehicle parked, the handbrake firmly applied and the transmission in Neutral (MT):
  • loose alternator/waterpump belt (aka drive belt).
Check that the alternator belt is OK and not loose i.e. correct tension etc.
(click on image)
  • faulty alternator (or voltage regulator - inside the alternator)
Start the engine and then connect a voltmeter across the vehicle's battery terminals. You should measure between 13.8V-14.5V DC with the meter. If not and the alternator belt is OK there may be a problem with the alternator or the voltage regulator (which is inside the alternator) Be safety aware if you do this as the engine is running
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Wendy anne 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 21
总计 463
