跳转到主内容
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
117 个问题 查看全部
Can I Use a Keyboard from an iBook G4 12" in Here?
so i have had my iBook G3 for a while, the keyboard sucks, though. it has the spongy effect, and after doing some research, i read that the keyboards from iBook G4's are much better, I was wondering if i could buy an ibook g4 keyboard and put it in my G3 with no problem, do they use the same connector? is the cable the same form? thanks in advance.
Also, I have an 800Mhz Model A1005
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
it is the solid white laptop, not the silver/clear one, not the clamshell either
完成的
添加一条评论
7个答案
已选择的解决方案
My daughter didn't like her iBook G4 12" 1.33Ghz keyboard so I installed a iBook G3 12" 800mhz keyboard on the 1.33 G4 and it worked great. Connector was the same, no fitting, it was a very simple swap. I think all iBooks G3 dual USB (not the clamshell) and the iBook G4 have the same keyboard connector. You can even fit a 14" keyboard in a 12" case but you'll have to fold the cable a little under the keyboard.
这个答案有帮助吗?
得分 5
2条评论:
Clearly you have experience with this matter but I'm afraid I disagree. Student IT has fixed around 20-40 iBooks without ordering any parts (sacrificing two broken ones to make one working one) and due to this method of use-what-you-have I distinctly remember trying to mix and match keyboards between the two versions and the connector of the G4 being smaller than in the G3.
Perhaps someone else could suggest their opinion in this matter?
完成的
QEII Student IT, please look at my other answer. You'll see a iBook G3 keyboard connected in a iBook G4 logic board. It connects perfectly and full working on my daughter iBook G4 1.33Ghz
完成的
添加一条评论
OK QEII Student IT so check this link and this pict:
http://www.flickr.com/photos/61008642@N0...
这个答案有帮助吗?
得分 3
4条评论:
Ok, thanks for clarifying anyways
完成的
Just confirmed that lemerise is right on this one. I've found it wise not to disagree with lemerise, especially within the realm of iBooks! :)
完成的
Ah Ah...Ben you're the expert here not me !! ;-)
完成的
Thanks for the clarification on this guys, I have removed my answer to avoid confusion.
完成的
添加一条评论
the iBook G3 12" keyboard does work and fit in the iBook G4 12" but the keyboard cable for the iBook G4 12" is shorter so you can't fit a G4 12" keyboard in an iBook G3 12".
You can, however, fit an iBook G4 14" keyboard in an iBook G3 12".
这个答案有帮助吗?
得分 0
添加一条评论
Will a ibook G4 12" keyboard fit inside a ibook G4 14"?
这个答案有帮助吗?
得分 0
1条评论:
no, ribbon cable will be too short.
完成的
添加一条评论
Can you used a ibook g3 keyboard in a ibook g4 14 inch?
这个答案有帮助吗?
得分 0
1条评论:
iBook G3 14" keyboard should fit in a iBook G4 14"
完成的
添加一条评论
Will an iBook G4 14" Keyboard fit into a 14" G3 iBook?
这个答案有帮助吗?
得分 0
1条评论:
I'd like to know the answer to this too..
完成的
添加一条评论
One thing that you can do is take the keys and the assembly from the G4 and install it on the G3 keyboard which would probably make it feel like a G4.
这个答案有帮助吗?
得分 0
1条评论:
I would not count on it. There are at least four differents key mechanisms in the ibook G4 line and they could not fit with the iBook G3 keyboard key mechanisms even if you can swap the complete keyboard between the G3s and the G4s.
完成的
添加一条评论
添加你的答案
Chris Green 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 18
总计 5,466
