跳转到主内容
Steam Deck 是 Valve 公司于 2022 年 2 月 25 日发布的游戏掌机。本页面包括 Steam Deck 搭载 LCD 屏幕机型的维修指南、拆解信息,以及疑难解答。机型代号1010。
My left stick "clicks in" when pressing it to the right?
My left stick started doing this a few months back. If I press the left stick to the right enough it's almost like I'm clicking in L3. It's a bit difficult to explain but it feels like something is clicking in. I got in RMA'd and it felt normal again when I got it. But now it's doing it again. I'm wondering if anyone knows what it is, what's causing it, or if it's even something one should be concerned about. I read somewhere that it could potentially be rubbing up against the wire that's for the touchpad and over time it could potentially cut the wire for the touchpad and break it. I don't think I can RMA it again due to my warranty being expired.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Please help me I was really hoping someone would know..
完成的
添加一条评论
2个答案
最有帮助的答案
I don’t see too much that could be getting stuck from the internals other than a small cable that’s part of the joystick itself. That doesn’t mean there isn’t some debris wedged in here. It would be worth popping it open and just removing the stick and cleaning everything up.Take a look and see if anything looks amiss.
Put it back together and see if that helps.Replace the stick if necessary.
这个答案有帮助吗?
得分 2
添加一条评论
I have the exact same issue. Did you fix it? And how?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
coldsteel77 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 36
总计 839
