跳转到主内容
期待已久的MacBook Air更新到来,带来了全新的英特尔酷睿i5处理器、升级了的视网膜显示屏以及众多其他更新。发布于2018年11月7日。
150 个问题 查看全部
Keyboard not funtioning, trackpad working
So the keyboard on this MacBook is not working while the trackpad does. The system boots right up into internet recovery.
Steps I took:
  1. Connected an external keyboard, didn't work (except for the arrow keys(!))
  2. Disconnected the trackpad cable inside the macbook
  3. Connected an external keyboard, works!
As I understand there was some spill on the keyboard, inside I don't see any traces of that and the logic board seems to work OK.
Any ideas?
Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Did you fully remove the logic board? Often times it’s the other side that get the damage (the side you don’t see)
这个答案有帮助吗?
得分 0
5条评论:
Yes I did, it looks very clean.
完成的
@egbertkappert - Carefully inspect the keyboard cables connection to the logic board for damaged pins and/or replace it.
完成的
@danj It's been a while. I did replace the cable, it didn't help. I find it strange that when disconnecting the trackpad cable the external keyboard functions fully, but when the trackpad cable is connected the external keyboard's keys don't work except for the arrow keys.
完成的
@egbertkappert - Then you have a short witching the cables path! Did you have a liquid spill into the keyboard or touchpad? One of them is the failure.
完成的
@danj Thanks for your answer. There was some spill yes.
完成的
添加一条评论
添加你的答案
Egbert Kappert 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 14
总计 61
