跳转到主内容
加入维修社区 - 创建账户
Motorola One 5G Ace 是于 2021 年 1 月 13 日发布的 Android 平板手机。
Why will my phone not turn on?!
I had slight salt water damage to the phone and it shut off and would not turn on. I opened it up replaced the usb port/head phone jack and battery as seems like the corrosion was only in that section after removing mother board as well. I try to turn back on by holding power button for ten seconds and get white light indicator at top and then a vibration and nothing else. If I continue holding the same thing happens. When I plug into usb to charge or get on PC, just a vibration. My goal is to get photos off... Help please?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi @dangraz,
Just verifying that there's isn't a recent backup available? Sometimes people forget that there is one, especially if auto backup to the cloud is enabled
Replacing the obviously affected components may not have been enough.
Did you check and clean the rest of the boards as well?
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dan Graz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 22
总计 968
