跳转到主内容
The Dell Inspiron 15 3558, part of the 3000 series, is a 15.6 inch desktop-replacement laptop with solid specs, plenty of storage, and long battery life.
6 个问题 查看全部
Can’t find my Wi-Fi network, but sees others?
I went to use my laptop today but I noticed it shows all my neighbors Wi-Fi but not mine. It was working fine earlier today but now it doesn’t show it. When I boot into Linux it sees it but not Windows. My Wi-Fi is Eero Router.
How can I fix this without reinstalling Windows?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@stechkid
I believed is the Wifi 6 ax mode in your router causing older drivers not to show up, which I had experienced it before.
is your wifi model intel 7265?
https://www.thm.de/its/images/stories/An...
Some possible fix,
1. update router firmware to latest
3. Download latest wifi drivers from Dell website and install.
https://dl.dell.com/FOLDER05736979M/4/In...
3. alternative drop the wifi mode on your router to wifi 5 mode
这个答案有帮助吗?
得分 1
添加一条评论
if it was working fine earlier today, then unless something updated or tried, it is a hardware problem. I have a router that doesn't transmit on one of the configurations. Fortunately, it has 3 Guest configurations and I switched it to another.
这个答案有帮助吗?
得分 0
2条评论:
When booted into Linux it sees it fine and it can see my other networks so my laptop’s fine
完成的
Hi @stechkid
Try just uninstalling the Wi-Fi driver in the Device Manger (devmgmt.msc) and let Windows reinstall it. This often fixes little problems.
完成的
添加一条评论
添加你的答案
80stechkid 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 160
