跳转到主内容
SolaDyne Table Top LED Lantern model number 7450, manufactured by SolaDyne through Aervoe Industries.
How to reattach the globe?
What is the trick to reattach the globe? I align the 4 screw into the slots on the base but nothing locks the globe to the base. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Have you tried turning the globe? There's usually only two possible methods of locking. Either align and then turn or align and then tighten!
这个答案有帮助吗?
得分 0
2条评论:
Yep. there are 4 screws that fit into slots on the yellow base. Once the screw heads are in the slots, it doesn't turn and doesn't lock
完成的
My next question would be are you sure you've used the correct screws, next is it possible to set the globe on them install the screws. If you could post some pictures of the slots in the globe and of the four screws your talking about?
完成的
添加一条评论
添加你的答案
KenS 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 134
