跳转到主内容
PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
395 个问题 查看全部
My controller isn't charging for some reason?
So, I've been trying to charge my DualShock 4, not sure if it is a newer model but it doesn't have the light on the touch bar so I think it's the model CUH-ZCT1U, and I do know it ends with U.
Otherwise than that, I have tried everything for it to charge, from resetting it, to using a different cable, nothing works. I'm pretty sure I need to replace the battery, but I can't order parts, since I'm not 18. If someone know how to fix this, it would be fantastic!
Regards.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It's probably not a battery problem, but the charging port of the controller that was faulty. You can use a flashlight to look at the port for a bend/broken pins, it's sometimes difficult to see if they are good or not. So sorry but the controller cannot be fixed without changing one of his parts.
这个答案有帮助吗?
得分 0
1条评论:
Doesn't seem like any of the pins are bent. The charger perfectly goes in the controller, too.
完成的
添加一条评论
添加你的答案
Kristian Prekpaljaj 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 53
