跳转到主内容
加入维修社区 - 创建账户
PS4 控制器型号 CUH-ZCT1。这款由索尼电脑娱乐公司于 2013 年 11 月发布的六轴 3.7 V 锂离子电池控制器维修起来并不复杂。(注:拆解指南不适用于此型号)
My controller isn't charging for some reason?
So, I've been trying to charge my DualShock 4, not sure if it is a newer model but it doesn't have the light on the touch bar so I think it's the model CUH-ZCT1U, and I do know it ends with U.
Otherwise than that, I have tried everything for it to charge, from resetting it, to using a different cable, nothing works. I'm pretty sure I need to replace the battery, but I can't order parts, since I'm not 18. If someone know how to fix this, it would be fantastic!
Regards.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It's probably not a battery problem, but the charging port of the controller that was faulty. You can use a flashlight to look at the port for a bend/broken pins, it's sometimes difficult to see if they are good or not. So sorry but the controller cannot be fixed without changing one of his parts.
这个答案有帮助吗?
得分 0
1条评论:
Doesn't seem like any of the pins are bent. The charger perfectly goes in the controller, too.
完成的
添加一条评论
添加你的答案
Kristian Prekpaljaj 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 121
