跳转到主内容
加入维修社区 - 创建账户
发售于2016年11月.PS4 Pro升级了硬件,使之能够支持4K游戏以及流媒体视频。
PS4 Pro Power Supply Overheating Problem?
I've noticed that my PlayStation is running unusually hot, which is causing the fans to produce loud noise. Upon closer inspection, I've determined that the power supply is generating the majority of the heat. Considering this issue, I'm wondering if purchasing a new power supply would be a viable solution. What do you think?
Thermal paste has already been replaced a few days ago.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
I find it uncanny that the problem has started in conjunction with new paste application, maybe redo that and see if it helps, unless you’re sure that couldn’t be it and you’ve done it a few times before :) sounds like the power supply is having to work extra hard to cool it down.. maybe
这个答案有帮助吗?
得分 0
2条评论:
It was hot before and still after the thermal paste replacement, I am now sure it is not because of the replacement because I have re-opened it uo to look at it and it is clean and everything is in the right spot. Thanks though.
完成的
Ah well then, is it turning off? Next I would check there’s no corrosion or degradation of solder joints, beyond that maybe a new psu is on the cards afterall, if it’s not giving heat warnings and turning off you could be right :) I’m sure there’s some expert ps4 fault finders here that will have better ideas
完成的
添加一条评论
添加你的答案
Jordan 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 18
总计 935
