跳转到主内容
Apple 公司 2022 年旗舰系列的顶级产品。iPhone 14 Pro Max 于 9 月 16 日发布,配备了 6.7 英寸 ProMotion OLED、全新 Bionic A16 芯片、三重后置摄像头系统和 5G 网络,是 iPhone 13 Pro Max 的继任者。
18 个问题 查看全部
Are iPhones water tested with just fresh water?
I was just wondering if chlorine would do any damage to the iPhone even tho is water resistant. Mine got splashed with a significant amount of water from the pool and I got the notification that the was water in the charging port, took 4 hours before the phone could charge again. The phone seems fine, just wanted to know if it’s something to worry about
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It depends how long it was soak, or did you dry it immediately but there are water probably in some parts inside and dried water cause corrode any expose components inside-cause corrode so many tiny pins inside, most components are integrated circuit these are very still vulnerable to short circuit and cause an issues….you will know however if your phone behave not normal means something wrong…Phone are not really water resistant as the (30 mins )….manufacturer claims, though can can cope with a bit splash, moist, never submerge to water (fresh, salt is worse as it penetrate the board or any components inside, the problem of phone being soak to water is…. when is on as all components are working 100% then suddenly short circuit…. this damage most of the components inside (ICs) can pcb or board main board whatever you gonna call it can be submerge to water or can it be washed absolutely yes but with no supply voltage it can be be clean with water or 99.9 % alcohol…I am a repair tech… mainly high end amps….
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 40
