跳转到主内容
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
153 个问题 查看全部
My iPad 6th Gen WI-FI had a weird battery level indicator
Recently, my iPad 6th Gen WI-FI's battery level indicator behaved weirdly. It started when I saw that the battery level was stuck at 17%, I decided to restart my device, the battery level was down to 8%, and then weirdly rised to 19%. I then let my device sit for a while, it now showed 15%. After that, it went back to normal. The analytics showed 1932 battery cycles which means around 61% battery health. I had this device since Christmas 2018.
Update: I didn’t properly plug in the charger. It dropped from 10% to 6% in 2 minutes. At first, it charged slowly, but it looks like it’s now charging fast.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sounds like you're due for a battery replacement. 61% battery health basically means when it says it has 100% charge on the battery icon, it really means it's more like 60%. You'll see this type of behavior when the health drops low. Typically I recommend people replace it at around 85%, at least on phones.
Looks like you can buy a replacement battery here on iFixit if you feel comfortable attempting your own repair. If not, call around local repair shops. iPad Air, iPad 5, iPad 6 Battery
iPad Air, iPad 5, iPad 6 Battery图片
产品
$49.99
这个答案有帮助吗?
得分 0
2条评论:
Update: my dad gave his iPad 9th gen to replace my iPad 6th gen, The newer iPad definitely has more battery life than the older one.
完成的
And also, i’m not sure if my 61% battery health calculation is correct, but i know that it now has more than 2k battery charge cycles.
完成的
添加一条评论
添加你的答案
Steven062010 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 72
