跳转到主内容
Repair information for Whirlpool dishwashers.
156 个问题 查看全部
Dishwasher isn’t filling with water or heating.
So our whirlpool dishwasher (model number WDF510PAYS2) has not been working. It gives an error of code 7-1 which means the heating element is out, but it also isn’t filling up with water. I hear it trying to drain though. It also produces some steam. So there’s gotta be moisture and heat coming from somewhere. What might be the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @andrew70387
There may be two problems.
1). Water inlet valve problem
In regards to the dishwasher not indicating a problem with the inlet valve I wonder if there's a problem with the drain hose check valve and the water is siphoning back in from the drain. If it does that's maybe where the water is coming from. It may be enough so that it doesn't detect a problem with the inlet valve, not electrical anyway. Float switch is indicating level is OK perhaps??
You could try raising the drain hose "loop" higher than the dishwasher (or as high as possible) and check or disconnect (or remove) the drain hose from the house drain connection point and then raise the hose above the level of the dishwasher and pour some water down the hose and check if it gets into the dishwasher. Worth a look anyway.
2). Heater problem
If you haven't already got it here's the tech sheet for the dishwasher that may help as it has the wiring diagram strip circuit diagrams for most of the important functions.
这个答案有帮助吗?
得分 1
添加一条评论
A defective water inlet valve may be preventing the dishwasher from getting water. Most often, the water inlet valve is the main reason why a dishwasher is not getting water.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrew 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 20
总计 175
