跳转到主内容
Repair guides and support for motorcycles manufactured by Suzuki Motor Corporation.
Why doesn't the speedometer or any lights work on my bike?
I have a 1998 Suzuki Intruder 1500, the bike will start and run without any issue, but it isn't getting any lights(high-low, turns, brake) and the speedometer and accompaning lights aren't working either. I just replaced the battery and the main fuse relay is fine as well. The only thing of note is the turn signal fuse is popping.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
I can't say anything about this bike, but on two separate occasions I've had clients bring to me dash clusters from their vehicles, and I found a fault on the ground pin of the main connection. After resoldering those pins to the PCB, dash board worked properly again.
Can you remove your dash to inspect if it is something similar?
完成的
I'll check it, the cluster isn't that hard to remove. I've had some mechanics I know saying the ignition might be the issue, gonna replace that and see.
完成的
添加一条评论
1个答案
You have to change speedometer gear in front alloy wheel, check the battery is it working properly or not for lights.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Austin Leonard 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 253
