Why is my mac so slow?
Booting up takes 3 Minutes and opening a program like word or mail takes over 1 minute.
I would run the onboard diagnostics to see if something is not working correctly. Your system will go into CPU Safe mode which reduces the systems CPU clocking to a crawl!
To get to diags restart your system and press the D key on your keyboard at startup. Here’s a good reference Mac startup key combinations
Let us know what you got for an error/s
这个答案有帮助吗?
Cannot Load EFI/Drivers/TestSupport.efi
This is the error message I get
@maximmotyka - That sucks! Thank you Apple! 😖🤬😖🤬
Did you try the online version as well? I hate winging it! Let’s assume the drive is just badly fragmented, then defragging the drive would be what I would do. But before you do that make sure you have a good backup!
I would get this product as I find it’s one of the better ones! Drive Genius it’s what I use.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 76
7条评论
Have you considered reinstalling the OS and switching to an SSD for faster read/writing speed?
由 dinoo_fixit 完成的
@dinoo_fixit - That’s a strong possibility but not the first thing I would do.
由 Dan 完成的
@danj Right, but maybe after fixing this issue, replacing the ten years old 7200 rpm HDD with an SSD and increasing the RAM wouldn't be a bad idea
由 dinoo_fixit 完成的
@dinoo_fixit - I don’t disagree! The core issue is likely something else.
由 Dan 完成的
@danj You're right
由 dinoo_fixit 完成的
显示更多的2条评论
