跳转到主内容
加入维修社区 - 创建账户
发布于9月16日,苹果公司的 "小型 "旗舰智能手机,其拥有6.1英寸ProMotion OLED,三镜头后置摄像头系统,5G,以及围绕前置摄像头和顶部传感器新设计的 "灵动岛"。iPhone 13 Pro的继承者。
[OIS issue] 3x telephoto camera vibrating and buzzing in video
Hi, i have a problem with ois with my 3x telephoto camera on my iphone 14 pro. It vibrates and buzz when i enable the video mode and turn the phone to right (in portrait) or up (in landscape).
I can hear the noise by putting my ear close to the camera.
Apple told me to do a system reset (with itunes) to fix the issue, i dont know if it can work. I have the 1 year warranty until november.
Videos here [the noise is heard only with high volume]
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
It is the stabilizer that is defective. You need a camera replacement for this issue. You can order it to apple to program to match your logic board serial number, other than that you can use after market but there will be a pop-up message "unknown parts" (it will not effect your camera operation).
Hope this helps.
这个答案有帮助吗?
得分 0
1条评论:
I ended up going to the apple store but the camera replacement didn’t fix anything and they gave me a brand new device, thanks anyway
完成的
添加一条评论
最有帮助的答案
I see this issue happen fairly often in my repair shop and it's most likely the camera itself that needs to be replaced. Seeing as you're still in warranty, I would just have apple take care of it. If they won't you could fix it yourself or have a trusted shop perform the repairs. Not sure about other countries, but here in the US you can order an OEM camera from the self service repair store. It'll come with the parts you need and you can rent the tools. By ordering it from the self service repair store it'll allow you to reprogram the new camera. Just be aware, while this is illegal for apple to do, they may void your warranty should you, or another third party perform the repair, despite using OEM parts.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Maxsenza151 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 53
过去 30 天: 175
总计 4,719
