Home button is not working after new screen replacement
I replaced the new screen on iPad Pro 10.5 but the home button is not working at all. I remove it and install the home button again but it is not. any idea why it is not working?
There could be several reasons why this occurs:
Those above would be the most common issues as far as I'm concerned, however it's not guaranteed that it's one of them.
Troubleshooting
*Each home button is paired with each iPad, meaning that replacing the original button will result in Touch ID not working. If that's your case, then sadly there's not much you can do yourself. The only way to fix that would be to do the repair through Apple. But just a heads up, according to their repair policy, they don't always accept to repair a device, no matter how much you pay them, if it has been opened up by someone that isn't an Apple Authorized Service Provider.
Good luck in fixing your device!
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 88
总计 593
was it working before the screen was replaced
由 daniel 完成的
Yes home button was working before...
由 iRepairMan 完成的
