跳转到主内容
Marshall Stockwell Bluetooth speaker
5 个问题 查看全部
Can I use my Marshall Stockwell without the battery?
The battery on my Marshall Stockwell does not retain charge anymore. I removed it and i will refurbished it with a company that dedicates to this. Can i use it without the battery in the meantime?
Update (07/02/23)
After posting this question here, I contacted Marshall through their chat support.
They told me that removing the battery and using the speaker connected to the power supply charger would not cause any damage.
I decided to give it a try, and I'm happy to report that it works perfectly.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Check first your power supply if it still working.
  • Remove connecting terminal of your battery and check the positive and negative terminal wires if there's still voltage output. I yes, may your battery was already damaged (Replace it). If no voltage output or has a lower voltage output, replace your power supply battery charger.
  • If you want to use it without the battery anymore, you can use a power supply that has the same voltage/current rating to your charger/battery. Connect the power supply directly to the battery terminals after removing the battery.
I hope it can help.
这个答案有帮助吗?
得分 2
1条评论:
Thanks for your reply, James!
完成的
添加一条评论
添加你的答案
Fokka85 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 28
总计 301
