跳转到主内容
任天堂于 2021 年发布的 Switch OLED 机型的维修和拆卸指南。
36 个问题 查看全部
Joy con is not recongnized but charges
Hi there,
So I have an OLED switch that the right joy con does not connect when the controller is docked. I tried with two sets and neither would connect but it’ll charge the Joycon. So I order a rail and replaced it, put everything back together and now I have the same exact issue. Works wireless but won’t connect to hand held but will charge.
Any help is appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
So you replaced the rail on the switch? I'd order a new connector assembly for the joycon as well. They are not hard to disassemble you just have to layout the parts in order to aid in reassembly. Watch the two springs don't jump out and go easy with the ribbon connectors.
这个答案有帮助吗?
得分 0
4条评论:
The assembly in the joy con? Wouldn’t that be ruled out since two different right side joy con don’t work but the exact 2 work on another switch
完成的
@pehter No idea pal, trying to work out what the problem is is a bit harder when the item isn't in front of you. So your joycons connect and work with another switch but not the one you swapped the rail on. If that's the case it could be a connector or a board issue. I'd take a look at the connector for the rail under a microscope for pins out of line or damaged etc.
完成的
https://youtu.be/R2RPtOZYkuk have you seen or tried this?
完成的
I’ve done various unpair and pairing to the second switch and going back to the bad one and no luck.
完成的
添加一条评论
添加你的答案
Pehter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 104
