跳转到主内容
Nintendo Switch Joy-Con 控制器的维修指南和信息。
How do I replace the R button on my Joy Con
I was planning on following this guide, but the button thing broke. Does anyone know where I can buy a new button thing?
Also how to I solder precisely enough to reattach a button that small?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Hello, Mewtwodestroyer.
The button is a kind of 'micro switch' and can be found with that term in your searches on various online retailers. Examples can be found here on Amazon and here on eBay for your reference.
As for the matter of how you'd go about soldering with the necessary precision, learning the fundamentals of soldering is the first step if it's something you haven't done before. Here's a link to an iFixit guide by a contributor that may help. The particularities mean this isn't something that can be answered so briefly, but with the proper size of soldering iron tip, a good, clear view of the board, the correct equipment, and a steady hand, you should be able to find success.
这个答案有帮助吗?
得分 2
1条评论:
Does anyone know the manufacturer part number of this micro switch? The switch probably costs near to nothing and all kind of replacement parts from retailers are most likely to cost 10-fold.
完成的
添加一条评论
You can buy a new ribbon assembly with the button already attached. Cheap too. Make sure you get the right side.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mewtwodestroyer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 23
总计 1,363
