跳转到主内容
9 月 24 日发布的苹果 2021 旗舰智能手机配备 6.1 英寸 ProMotion OLED 显示屏、全新三镜头后置摄像头系统和 5G。iPhone 13 Pro 是 iPhone 12 Pro 的继任者。
59 个问题 查看全部
Can I replace the back glass with using the existing camera glass
My IPhone recently broke on the back and it is not bad at all only a minor crack at the edge on left bottom. But I want to replace the back can I replace without removing the back camera glass. I found some cheap ones on Amazon but they have larger camera holes which I don’t want to use. Thanks for the help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
larger camera hole glass is the one to use if you don't want to remove the camera lens, if your using heat to remove the old glass only use around 240c as it has less chance of damage to other parts
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Var27 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 60
