跳转到主内容
加入维修社区 - 创建账户
The Infinity v2 10.1 inch tablet, running Android OS , was introduced in 2014.
powers on but screen is black
My device powers on and the sound in the beginning plays when you turn it on but the screen remains blank. I tried a hard reset where I held the volume + and the power button at the same time but still having the same problem. I've tried every other combination of buttons to push as well....nothing. Please I need help, we bought this about 6 mos ago and MAYBE used it 10 times if that. For paying $800 for this device, I'm so upset that it broke so quickly especially because it just sat in the corner for the remaining time untouched. HELP
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Hi @jenniferlu17870,
Please verify the make and model number of the tablet?
The device you selected for this question was introduced nearly 10 years ago and most probably is not even available anymore. Certainly not at that price. You can get them 2nd hand for $50.00
完成的
Are you charging the battery ?
完成的
添加一条评论
1个答案
Put a bright flashlight sideways when powering on. If you see the colors of the display and, well, the image, you will need a new display, as the backlight driver (the chip in the display) may have gone bad. Try taking the device apart (Infinity v2 10.1 LCD Screen Replacement don't need to follow unplugging everything else and de-soldering the battery) and unplugging and replugging the display. If this doesn't help, you may need a screen replacement.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jennifer Lugo 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 42
总计 1,571
