跳转到主内容
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
374 个问题 查看全部
My keyboard and trackpad aren’t being recognized
Guys I replaced the track pad and it’s completely in and flush.
All of the connections are back in neatly but now keyboard and trackpad aren’t being recognized by my logic board.
But prior to replacing they were. Why is this ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sounds like the trackpad cable which carries both the keyboard and trackpad data to the logic board wasn’t seated fully or is damaged. Here’s the replacement MacBook Air 13" (Mid 2011-Mid 2012) Trackpad Cable
MacBook Air 13" (Mid 2011-Mid 2012) Trackpad Cable图片
产品
$14.99
这个答案有帮助吗?
得分 0
2条评论:
And what if this doesn’t fix it ?
完成的
@laroyfitchjr - I would then suspect you got a bad trackpad as the trackpad carrie’s both data signals to the logic board via the cable.
完成的
添加一条评论
添加你的答案
La'Roy Fitch Jr. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 44
