跳转到主内容
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 个问题 查看全部
Replacement battery has manufacture date of 2015-03-30
I just purchased and received a replacement battery for my mid-2014 MBP 15". Upon installing the new battery and firing up coconutBattery, it is reporting that the new battery was manufactured 2015-03-30. Is this correct or just an error? I really hope my new battery has not been sitting on a shelf for 8 years.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
I just installed a new battery from Ifixit yesterday and coconut battery reports that it was manufactured in 2015 and the health of the battery is at 91%
这个答案有帮助吗?
得分 3
添加一条评论
i doubt its an error, that is more than likely the correct date
这个答案有帮助吗?
得分 2
6条评论:
Anything to be concerned about?
完成的
@dustincarp20440 it might be ok as a lithium battery has 600-1000 cycles so check what cycles the battery has and if its low it should be ok
完成的
I am having the same problem and I am quite concerned. Batteries do age on the shelf and these should not be sold as new stock anymore.
完成的
The new battery has not been a great experience for me. I honestly probably won't bother buying iFixit batteries in the future based on this experience. They sold me an 8+ year old battery that constantly goes from 50-60% charge to dead even after multiple attempts to calibrate it. I've done all of the standard troubleshooting such as nv ram reset and letting it completely drain and then charge to full. It takes 4+ hours to fully charge from 0% but then depletes within 2 hours even with very light workloads or just being in sleep mode.
完成的
I've ordered a battery from ifixit as well for my 2015 model. Coconut battery shows the exact same date to me, maybe it's a manufacturer's thing? It's been working perfectly for 2 months now with pretty heavy use. Yours may just be defective?
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Dustin Carpenter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 240
