Drone tilt's upon takeoff
Drone tilt's to one side upon takeoff
Have you checked that all the propellers are situated in their correct position and are orientated correctly i.e. not upside down?
usually propellers are marked as to where they should be place on the drone and also what side is facing up.
Most user manuals for drones show how to connect the propellers to the body of the drone
这个答案有帮助吗?
Check nothing is interfering with the motors on the side that lifts last. One motor isn't spinning up as fast as the others causing the drop in one side. It's possible you may need to fit a new motor. Try a drop of fine oil on the shaft at the bearings incase they are a bit dry.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 81
2条评论
@angelocenotti got a make and model for this Drone?
由 oldturkey03 完成的
it is a protocol galileo stealth w/camera
由 Angelo Cenotti 完成的
