跳转到主内容
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
Computer crashes to a blank green screen.
I’ve recently built my first pc and for the 1st day it was running great. Yesterday and today hasn’t been the same. After only a few minutes of running the pc will crash in to a blank green screen. Any tips? Anyone else ever have this problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi @koithyboi,
What is the make and model number of the motherboard and the GPU card?
Try disconnecting the SSD (HDD?) and check if you can get into BIOS OK with a display.
Have you checked the monitor's working OK i.e. can you view the OSD menus?
完成的
添加一条评论
1个答案
What operating system is it running on?
这个答案有帮助吗?
得分 0
2条评论:
Was running windows 10 when it started. Upgraded to windows 11 only for it to crash more often
完成的
It could be a bios issue or corrupted files, maybe you should upgrade your drivers, it could be a monitor issue too
完成的
添加一条评论
添加你的答案
koithyboi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 111
