Where is the cheapest place to buy headlights?
I've always found the Auto Wreckers will do it cheaper than most. The cheapest of these will let you take it off yourself using your own tools. The biggest of these here is U-Pull-it, but you will need to check locally where you are. Go to their website first and check their stock lists to hunt for your make & model or research to find equivalents that fit your vehicle. Some you can call to check if they have stock.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 123
Ehud, do you mean headlight bulbs or the entire headlight assembly?
由 Jerry Wheeler 完成的
@ehudzaltzman What model year is your Subaru Outback?
由 Andrew S 完成的
