跳转到主内容
The Wing is a flagship twist-slate Android smartphone released by LG in 2020. Identifiable by model number F100, followed by variant-specific characters.
How to change the back glass
How to change the back glass?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Like @vojtech59738 said any good high heat source will work fine, however a tool like a hot plate is the "proper" way to do it. You can get the "China special" off Amazon or one from iFixIt. As far as the exact way to do it on this exact phone this tear down should help: https://www.youtube.com/watch?v=Ms8UZ46-...
https://www.amazon.com/Soiiw-Microcomput...
CPB Heating Pad for Screen and Battery Replacement
A large heating surface for quickly and efficiently warming and loosening adhesive for screens and back panels on electronic devices.图片
产品
$89.99
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Same like most phones today, heat the back glass with hair dryer or somethink like this, till 80°C is totally safe, after remove the glass using some slim plastic, can help also little bit isopropyl alcohol. Clean the frame from old glue and place new back glass, when you get some lower quality part i recomend also use b7000 glue.. Only be carefull with cameras, dont touch the lens etc.
这个答案有帮助吗?
得分 5
添加一条评论
添加你的答案
Sultan Bin Shaher 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 259
