跳转到主内容
加入维修社区 - 创建账户
这是一款由 Saeco 开发并以 Starbucks 品牌重新推出的易用型家用浓缩咖啡机。这款咖啡机非常适合日常饮用浓缩咖啡的用户,且具有出色的做工和产品寿命。
Pump or mushrooom valve issue?
I am now tasked with repairing a Starbuck Barista (or Saeco SIN006, same parts different colors). The owner had it for the past 20-something years, and, not knowing anything about espresso machines, had the pump replaced about 2011. I recently thought it would be a good idea to clean the somewhat clogged up portafilter, so I used the appropriate cleaner (caution: this is not a descaler) as I didn't want to use vinegar or CLR and its everlasting smell. So the good news is the portafilter and shower screen are now completely clean. The bad news is the issue I was trying to get rid of didn't go away.
First symptom
  1. Whenever I close the portafilter against the running pump, the pump noise slowly dies out as pressure builds up (normal, as it is a pressurized portafilter).
  2. Keeping the portafilter closed still allows some water to drip, whereas it should be fully watertight (or so I understood)
Second symptom
  1. When I open the portafilter again, water should come out easily and the pump noise should increase as pressure in the boiler decreases.
  2. However, this isn't the case: I only get a few drops (the content of the portafilter, basically), but the pump is still humming slowly and doesn't provide any additional pressure.
What I already tried:
  • Just after reopening the portafilter, turning the pump off for a few seconds to a minute (highly variable) will usually allow a steady stream of water to come through the portafilter. By doing so, I assume I the pressure inside the boiler diminishes.
  • Removed shower screen just in case = no effect, same symptoms
  • Removed portafilter after pump has slowed down to a low huming noise. (WARNING: before anyone says so, yes, I know this is DANGEROUS should there be any pressure build-up in the portafilter. That's why I did so behind a wet towel to avoid any splashes. However, from symptom #2, I knew there wasn't any pressure. If unsure, don't do it) = suprisingly, no effect either!
  • At this step, the only obstacle on the pressurized water path should be the mushroom valve.
  • I also tried to remove the mushroom valve from the boiler, but years of lime build-up took their toll and I couldn't do it and just bent the tool. I didn't want to use WD-40 for obvious reasons.
  • Dismantling the pump, just because. Here are some pictures:
Inlet plastic tube is reasonably clean. Rust marks are actually on the outside. Plunger is a bit loose in the tube.
Plunger O-ring isn't as tight as video tutorials on ULKA pump show it to be, but snug enough it doesn't slide off by itself.
Plunger plastic ball appears to sit properly on the thin end of the plunger.
High pressure side has a bit of scale build-up, but nothing out of the ordinary
What I can't try
Logic would require one to use a manometer to know the pressure provided my the pump. However, I have no such instrument.
I made a short video describing the issue. In this video, shower screen has been removed and there's obviously no coffee in the portafilter.
  • 0 to 11": pump noise dies down as pressure builds up against closed portafilter.
  • 18 to 27": I open the portafilter, very small amounts of water comes out, pump noise doesn't resume.
  • 27" to 35": I repeat the manoeuver, to no avail.
  • 36": pump is turned off, portafilter is open.
  • 48": pump is turned back on, water flows through portafilter.
  • 1': portafilter is closed against running pump
  • 1'10": portafilter is opened again, no flow.
  • 1'17": pump turned off
  • 1'24": portafilter still open, pump turned back on twice, no flow.
  • 1'34": portafilter open, pump turned back on after a few seconds off-time, correct flow.
What is the problem with this machine?
Actualización (07/04/23)
Update: I ran a cycle of descaling using the recommended instructions / ingredients (100ml lactic acid in 1 l of water). I unplugged the heater element so as not to waste electricity. Water came out milk-ish white. I am now in the rinse cycle.
However, a two new issues appeared:
  1. when I close the portafilter, the pump never stops. It doesn't even slow down, and water is leaking from the top of the portafilter.
  2. The portafilter itself developped rust under the basket for some unknown reason
I can't even check that the original problem disappeared!
ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
Perhaps you should have a look inside the heater. The teardown shows how to do this. I had a similar issue on a Saeco SIN17, this guide helped.
Starbucks Barista图片
指南
Starbucks Barista 拆解
难度:
中等
Saeco Magic Capuccino SIN017 锅炉内升降管疏通图片
指南
Saeco Magic Cappuccino SIN017 锅炉内升降管疏通
难度:
中等
这个答案有帮助吗?
得分 1
添加一条评论
An update: I'll first try a descaling as I'm pretty sure the last one was 8 years ago.
I had a look at the teardown guide, but the steam valve knob wouldn't budge. I'll try again.
On the picture, my machine doesn't have the parts circled in green and yellow (not sure what the green one does)
On another half-boiler from a SIN017 I had previously, I tried to un-screw the mushroom valve holder (red), to no avail. No matter how hard I tried, being with screwdriver, washer or provided tool, il wouldn't rotate. Hopefully removing it won't be necessary.
这个答案有帮助吗?
得分 0
1条评论:
Part circled in green is necessary when using the single basket, according to Stefano's Espresso Care. So, not absolutely necessary.
由完成的 分享
添加一条评论
Try a shot of CRC "FOOD SAFE" penetrating oil on the outside of the valve holder. It will seep down to the bottom of the threads. Then let it sit for a few hours/days.
The penetrant isn't magic, I still had to use a fair bit of force to break the valve free. But I was able to break it free.
CAUTION, be careful. Do NOT round off the notch on the valve, or you will have to grind the notch straight vertical again.
这个答案有帮助吗?
得分 0
添加一条评论
Water leaking from the top of the PF indicates a gasket leak from one of two places.
#1. The head gasket.
First CLEAN the gasket and top of the PF of any coffee grounds, then try again.
If it still leaks, you have to replace the gasket.
#2, The red gasket inside the PF has torn, and is not sealing against the basket.
This requires rebuilding the PF.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pat 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 34
总计 1,131
