跳转到主内容
Released July 12, 2002. Identified by model number K45SSWH.
33 个问题 查看全部
Will not turn on at all after cleaning. No motor running
Kitchen aid mixer K45SS, bought in 70s, won't come on. I cleaned it by removing screws and cleaned screws and replaced. Oiled moving parts. Put everything back like it was. Now, won't turn on at all. Is there something not adjusted right for it to refuse to work. No motor sound, no nothing. Thanks, Debra Huffman
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Debra,
Unfortunately there are a few things that could be wrong, but I would start with the on/off switch. I have no idea what your technical abilities are, but if you can get access to it and use a multimeter set to Ohms, you can check if the switch (unplugged from the outlet please) to see if you get a different reading other than infinity when the switch is in one of the on positions. If you do, then I would check the motor brushes (which are under those screws on the side). There should be a spring in there that has to be properly aligned with the brush that pushes against the motor rotor itself. If you say that you took them out and cleaned them, I would suspect you maybe didn’t put them in with the springs properly aligned. And they should be cleaned with electrical contact cleaner (not soap), so go buy a can (an auto parts store would have some) and re-clean them, if needed, then carefully reinsert and see if that helps. The mixer is old enough, you may need to get replacement brushes and springs if they are worn far enough where the spring that pushes them in isn’t “springing” any more. Hope this helps.
这个答案有帮助吗?
得分 1
1条评论:
Thanks Chris, not sure if this helped OP, but definitely helped me! The springs weren't aligned properly.
完成的
添加一条评论
添加你的答案
Debra Huffman 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 65
总计 629
