跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly guides for Panasonic DVD players.
I can't record in my Panasonic dvd recorder
I can see the dvd content but I can't record anything because this message: Please check the disc.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
Hi @antoniochavez,
What is the model number of the player?
Has it worked OK before when trying to record discs?
Have you checked that the disc type is compatible with the player e.g. DVD-R, DVD+R, DVD-RW, DVD+RW, DVD-RAM or DVD-ROM?
Have you tried another disc in case this disc has been finalized?
完成的
DMR-EZ28
Yes. Maybe after 3, 4 or 5 discs.
Yes. I have had recorded both kind.
完成的
@antoniochavez
Here's the type of disc that you can use to record, just to make sure that they're the correct type.
Have you tried with any empty discs i.e. no files on the disc at all? It may be that there's not enough storage space left on the disc to record
Do the discs that you're trying to record to have files on them that were recorded on another player or were they all recorded on your player?
DVD-R, DVD-R DL, DVD-RW (DVD+R, +R DL or +RW discs already recorded on another DVD recorder may not be recordable on your player. Panasonic is funny that way
完成的
添加一条评论
1个答案
It’s all the Capacitors need to be replaced!,
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Antonio Chavez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 155
