跳转到主内容
加入维修社区 - 创建账户
Miyoo Mini是由Miyoo(乐米游)于2021年12月2日上市的一款开源掌机。Miyoo Mini极其小巧,您可以随时随地放入口袋中、或从口袋中拿出。 基础定价为269.00人民币。
Onion os is not loading onto my mini plus. (Noob)
I have a Miyoo mini plus Version 202303262339(im going to assume this version is up to date) I brought a new reader and micro usb 256 card that i formatted using my laptop....no special program. I downloaded Onion OS 4.2.0 unto my laptop then transferred the six files to my usb card. I transferred my USB card to my Mini plus, and turned it on, the new OS isnt loading, I continue to get the default OS that came with the Mini Plus. Any help will be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
I believe the issue you are facing is due to your SD card size.
“Large Storage Capacity: With a 64GB microSD card included and support for up to 128GB of expandable storage, the Miyoo Mini Plus+ offers ample space to store a vast collection of retro games, giving it an edge over other handheld consoles with limited storage options.”
Per Droix, link below
https://droix.net/product/miyoo-mini-plu....
这个答案有帮助吗?
得分 0
添加一条评论
You need to format it as FAT32, and any card above 32GB will be formatted as exFAT by default. For those cards, you need to use a tool such as FAT32 format (guiformat) : https://lecrabeinfo.net/telecharger/fat3...
So format the card as FAT32, extract/ copy all the files for OnionOS on that (FAT32) card, put it back in your Miyoo Mini (Plus), turn it ON, follow the set up on screen, (copy ROMs and BIOS files on the card only at that stage), and enjoy your new firmware
这个答案有帮助吗?
得分 0
添加一条评论
Dude, I'm also having that problem. Mine has stock firmware at 202305something so I've downloaded OnionOS 2,4-RC, formatted a SanDisk 64GB microsd as FAT32 using guiformat and all goes well during the installation of OnionOS. However, once the system reboots, I get Miyoo splash boot screen and the console freezes. I have already reformatted the microsd, copied the files over and went through the installation process but the same problem happened again.
Any clues what could be the issue?
这个答案有帮助吗?
得分 0
添加一条评论
You're on firmware 202303 update to 202306 wich is most current as of today. Also for the firmware update use a fat 32 32k cluster ruffus formatter sd card preferred a 32 or less one with only the firmware 306.img on it and plug it to one of your pc'cs usb ports(not front or extension ones) if u see a rocket let it do its thing until it reboots and shows charging then you can use your big SD card as fat 32 with the onion os in it. I'm on a 512gb card so any decent brand card will be fine for the OS
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
75whysoserious 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 87
总计 6,899
