跳转到主内容
加入维修社区 - 创建账户
这台13寸的MacBook Pro使用四核英特尔十代i5/i7处理器和锐炬Plus核芯显卡,于2020年5月发布(型号为A2251/EMC3348,拥有4个雷雳3接口)
MacBook won't stay in dfu mode long enough to restore?
I wanted to do DFU mode which is restoring the Macbook but in the last step is jumps out and goes to locked photo!! I can't install from the internet recovery like 2014 model nither from USB bootable!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Do you get any errors in Configurator?
完成的
添加一条评论
1个答案
What is preventing the OS reinstall from Recovery Mode? The model you have should support it. Does it give you an error when you try to reinstall from Recovery Mode? If so, what is the error? Do you know if the device is Activation Locked to an Apple ID?
这个答案有帮助吗?
得分 0
6条评论:
Before this I went to Recovery mode which is Comand+R but I did a mistake and I formatted SSD then never boot to recovery mode or passed the Apple logo.
完成的
Macbook is not passing apple logo, stuck on apple logo
完成的
Maybe you can try holding Command+Option+Shift+R on startup. That should hopefully open a version of Internet Recovery Mode that will allow you to reinstall the OS that shipped with the computer. You could also try Command+Option+R. Good luck!
完成的
I did this as well. But it goes to black screen never apple logo with progress bar are showing up
完成的
Interesting! It sounds like it may have an issue with the firmware—I'm not sure how to resolve that if DFU mode isn't working for you. It might require contacting Apple and sending it into them to resolve, or maybe a local repair shop would be able to help you out? Good luck!
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Armin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 21
总计 756
