跳转到主内容
此为等候许久的Mac mini硬件更新。处理器方面支持选配3.6GHz四核i3,3.0GHz六核i5,及3.2GHz六核i7英特尔CPU。
Conductive glue for PRAM battery?
Dear Community,
the PRAM battery is next to the SSD on the motherboard.
It is attached to the motherboard at two points.
Due to an accident, now only one of these points hold the PRAM battery in place.
I would rather avoid repair service if possible.
As I looked at the attachment, my assumption was that some kind of conductive glue was used to hold the battery in place.
If I used that to reattach it, am I taking a risk?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
In this picture it looks like the PRAM battery is soldered onto the board at two contact points, though I'm not sure about that because I don't have a board to inspect in person. If it is soldered, which it looks like it is, then you would need to resolder the connection to repair it. I'm not aware of any other method of connecting it to the board. Good luck!
这个答案有帮助吗?
得分 0
2条评论:
Do you think a kind of wire glue, which is said to replace soft soldering, would also do, which is said to be able to make conductive bonds?
完成的
I'm not sure! I've never tried that. If you are able to do that successfully, let us know :D
完成的
添加一条评论
添加你的答案
Patrik Nusszer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 213
