跳转到主内容
加入维修社区 - 创建账户
The Forester was introduced at the Tokyo Motor Show in November 1995 as the Streega concept, and made available for sale February 1997 in Japan, and to the US market in 1998. The Forester was one of the first emerging crossover SUVs.
a/c doesn't work
clutch on a/c doesn't work. How do I fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You first need to be sure why it's not working. Your ac has a low limit switch which means if the freon has leaked the clutch will not engage, if the ac relay ihas gone bad the clutch won't engage there are several other reasons. Most likely one of the two above will be the problem. If possible you need to take it to an ac repair man that you trust.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robin Ballard 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 13
总计 194
