跳转到主内容
A1708/EMC 2978—于2016年10月上市,这台入门级MacBook Pro保留了它传统的功能键(相对于OLED触摸条)。功能键版本带有英特尔酷睿i5和2个雷电3端口。
MacBook wont turn on anymore after SSD upgrade
Hello to everyone!
Please I need help with this following strange case.
1- We updated SSD in some of our macbooks with a non brand Chinese SSD.
2- We did it in more than 7 Macbooks without issues.
3- Suddenly, 1 of the SSD's (we called killer SSD), is just being placed on laptop, we try to enter in recovery mode to reinstall MacOS by turning it on, but they wont react. We tried in second laptop, with exact same results..
After this, not even possible to instal anything, the laptops wont turn on anymore... so we are quite confused on what is going on, or what we can do with this laptops now.
What we tried with no success?
- PRAM and correct SMC (SMC for this model)
- Disconnecting battery and trying to turn on
- Reinstating the original drive
- Leaving battery to charge for 1 night
Please, are you able to give me some other possible troubleshooting steps I might be missing? I never saw a Macbook Pro not reacting after PRAM and SMC reset to this kind of power issue... I hope the SSD did not kill both macbooks!
I can not find the logic in how a SSD can kill a laptop, but never say never because Apple in some cases is special, and more with non original hardware.
Thanks in advance. Kind Regards!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Did u guys find the issue
完成的
Many of the 3rd party adapters with an M.2 SSD have had issues, either the adapter or the inserted SSD.
I personally would stick with a real Apple SSD or a direct pin compatible unit like what OWC offered. Apple not sticking within standards makes upgrades extra hard and costly.
完成的
添加一条评论
1个答案
What happens when you put the original working SSD back in? If that fails to work this SSD could be bad or there is some code on it which is messing you up.
这个答案有帮助吗?
得分 0
8条评论:
Thanks for your answer!
Unfortunately not doing nothing with original ones anymore.
The SSD's they were new. I am trying to get warranty from supplier but he is based in the SSD and not wanting to cover the laptop, so I wonder how to reborn them if possible.
I can not see how SSD can kill a macbook pro, but maybe something I am missing.
完成的
@dany71780 - What is the SSD? Type, brand and model. It this via an adapter?
完成的
@danj Thanks Dan, is not an adapter, is a Chinese one compatible without brand. Our supplier will refund the money but he is not having much info to know why or what to do. Is:
"1TB NGFF M.2 NVME SSD voor Apple MacBook Pro 2016 & 2017"
But as reported, we did install other 10 in total, and this SSD we tried in 2 laptops (In case was the laptop) but they now not turning on anymore, which I find VERY strange to be honest.
Bu I am doing several times SMC and not doing nothing the laptop. Not sure if there is other options to see what is happening, but the laptops not reacting at all.
完成的
@dany71780 - I would inspect the socket connector. Some of these units don’t have a good edge so the pins in the socket get damaged.
完成的
Thanks @danj!
But can that damage make the laptop not turning on anymore?
I can imagine the SSD is not detected anymore if this is damaged, but the laptops are not reacting to anything, and not turning on even the LCD
:_
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Dany 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 325
